Do It Yourself (top questions and answers) FAQ's
Old 09-25-2007, 06:50 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Question Do It Yourself (top questions and answers) FAQ's
This thread will be continuously updated.
Check back often!
We are not responsible for any mishaps while you are wrenching, knuckle busting, throwing tools, kicking vehicles, stomping, whining, drinking, or possession of you or your rig by any entity....... Always consult a manual before attempting any wrenching and I advise you to stay within your skill set. If you’re expanding your skills, work on the easy stuff 1st to gain skills and the necessary scars on the hands to fall into the "working man/woman" category.
With that said lets open the door.
Maintenance log (google docs template)
https://docs.google.com/spreadsheet/...XpVZkxNdURVRXc
if you have any questions about this pm SHRPSHTR325
sample blackstone oil analysis (transmission fluid at 115k miles)
https://drive.google.com/file/d/0B3S...it?usp=sharing
Longevity And Horse Power
https://dodgeforum.com/forum/1st-gen...-your-rig.html
rear main seal replacement 5.2/5.9
http://www.mediafire.com/?rxl4y6r564y9sl2 (pdf)
Trailer Tow ratings
http://www.campinglife.com/tow-ratings-database/
Starter
Starter Replacement on the 5.9L and 5.2L and Starter Diagnostic Techniques.
https://dodgeforum.com/forum/1st-gen...-and-5-2l.html
https://dodgeforum.com/forum/1st-gen...ng-relays.html
https://dodgeforum.com/forum/1st-gen...acting-up.html
Tires
https://dodgeforum.com/forum/1st-gen...pressures.html
Tire Height
https://dodgeforum.com/forum/1st-gen...8-durango.html
Pressures
tire size calculator/converter(xxx/xx/xx - yyXyyXyy format)
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Suspension
https://dodgeforum.com/forum/1st-gen...sh-repair.html
4 Wheel Alignments and correct Suspension Height
https://dodgeforum.com/forum/1st-gen...ment-woes.html
Tie Rod Ends
https://dodgeforum.com/forum/1st-gen...ment-help.html
4X4 Suspension Torque specifications
https://dodgeforum.com/forum/1st-gen...durango-2.html
Swap parts on 1998 to 2003 Spindle/Knuckle for larger brakes
https://dodgeforum.com/forum/1st-gen...-advice-3.html
Energy Suspension
Energy suspension cataloge download (click HERE)
Squeaky Front End:
https://dodgeforum.com/forum/1st-gen...3-durango.html
Master Window Switch Fix (Drivers Side Switch)
https://dodgeforum.com/forum/1st-gen...aning-diy.html
lockout jumper (bypass)
https://dodgeforum.com/forum/2439583-post8.html
https://dodgeforum.com/forum/1st-gen...r-windows.html
Side Mirror swap (power and heat)
https://dodgeforum.com/forum/1st-gen...ml#post2529749
T/S Lift
https://dodgeforum.com/forum/1st-gen...-bar-lift.html
https://dodgeforum.com/forum/1st-gen...-durangos.html
https://dodgeforum.com/forum/1st-gen...-question.html
Lets see your lifted durangos
Exhaust
https://dodgeforum.com/forum/1st-gen...et-exaust.html
Daytime Running Light Module
https://dodgeforum.com/forum/1st-gen...mp-module.html
Custom Cold Air Intake (CAI)
https://dodgeforum.com/forum/1st-gen...m-air-diy.html
https://dodgeforum.com/forum/1st-gen...s-mileage.html
https://dodgeforum.com/forum/1st-gen...ir-intake.html
https://dodgeforum.com/forum/1st-gen...e-ram-air.html
https://dodgeforum.com/forum/1st-gen...-for-5-2s.html
https://dodgeforum.com/forum/1st-gen...-brew-cai.html
talk about gas mileage
https://dodgeforum.com/forum/1036359-post14.html (courtesy of HankL)
Plenum Gasket Replacement
https://dodgeforum.com/forum/1st-gen...ml#post2678077
Kegger Intake Mod Thread (2nd Gen Ram Thread)
https://dodgeforum.com/m_1162946/tm.htm
4.7L Head Rebuild
https://dodgeforum.com/forum/1st-gen...d-removal.html
Compression Testing
https://dodgeforum.com/forum/1st-gen...ml#post2844206
Evap leaks
https://dodgeforum.com/forum/1st-gen...ml#post2195984
https://dodgeforum.com/forum/1st-gen...ml#post2224586
https://dodgeforum.com/forum/1st-gen...ml#post2654866
Cleaning Throttle body & IAC
5.2L and 5.9L
https://dodgeforum.com/forum/1st-gen...ttle-body.html
4.7L
http://www.mediafire.com/?k0742k5tvj1dqxh
Stock Electric Fan Replacement
https://dodgeforum.com/forum/1715720-post62.html
https://dodgeforum.com/forum/1st-gen...-colors-2.html
Harmonic Damper Puller
https://dodgeforum.com/forum/2586154-post1.html
Alternators
Alternators and Alternating Current.
https://dodgeforum.com/forum/1st-gen...questions.html
Direct Link to Download a 2002 Durango Service Manual
http://www.mediafire.com/?2cg2hgim2zz
Seat Fix
Free Heated Seat Fix
https://dodgeforum.com/forum/1st-gen...-for-free.html
Sliding Seats
https://dodgeforum.com/forum/1st-gen...eat-issue.html
lumbar support fix
https://dodgeforum.com/forum/1st-gen...ml#post2448885
Power Window Motor Repair
https://dodgeforum.com/forum/1st-gen...ean-green.html
https://dodgeforum.com/forum/diy-do-...ean-green.html
how to video
https://dodgeforum.com/forum/1st-gen...ml#post2378075
clockspring replacement
98-00
https://dodgeforum.com/forum/1st-gen...ml#post2453123
http://www.mediafire.com/?ucjavuazmbdbisl
Power lock Repair
rear hatch not locking
https://dodgeforum.com/forum/1st-gen...ml#post2447259
Durango Stuck in park(usually in the cold)
https://dodgeforum.com/forum/1st-gen...k-in-park.html
Wiper Conversion Gen 1 to Gen 2
http://www.durangoclub.com/forum/viewtopic.php?t=3593
Emissions 101
https://dodgeforum.com/forum/1st-gen...ode-p0441.html
Oxygen (O2) sensor layout
https://dodgeforum.com/forum/2744866-post57.html
https://dodgeforum.com/forum/2745210-post61.html
Fan Motor Blower Resistor Fix
https://dodgeforum.com/forum/1st-gen...er-switch.html
PDF file -->http://www.mediafire.com/?54w3ec8hi9cht5n
1998-2000
https://dodgeforum.com/forum/1st-gen...istor-fix.html
https://dodgeforum.com/forum/1st-gen...r-problem.html
2001-2003
https://dodgeforum.com/forum/1st-gen...ml#post2840693
Add overhead A/C
98-00
https://dodgeforum.com/forum/1st-gen...ml#post2904557
ATF+3 and ATF+4 Fluid Facts
https://dodgeforum.com/forum/1st-gen...f-4-facts.html
(Transmission Purging)
https://dodgeforum.com/forum/1st-gen...nsmission.html
Chrysler Approved Transmission fluids
http://www.centerforqa.com/licensedatf4brands.html
Reading on ATF+3 and +4
http://www.allpar.com/mopar/transmissions/fluids.html
https://dodgeforum.com/forum/1st-gen...1-durango.html
Fluid Capacities
https://dodgeforum.com/forum/2582906-post16.html
Oil Pressure sensor (switch)
Talk on Oil
https://dodgeforum.com/forum/1st-gen...nions-mmo.html
https://dodgeforum.com/forum/1st-gen...d-battery.html
https://dodgeforum.com/forum/1st-gen...wers-faqs.html
oil filters
http://minimopar.knizefamily.net/oilfilters/index.html
oil filters revealed (internally)
https://dodgeforum.com/forum/1st-gen...ml#post2836764
Discussion on oil filters
https://dodgeforum.com/forum/1st-gen...iscussion.html
Speed Sensor/ABS Sensor Replacement
https://dodgeforum.com/forum/1st-gen...ensor-diy.html
Transmission Output Sensors
https://dodgeforum.com/forum/1st-gen...abs-light.html
https://dodgeforum.com/forum/1st-gen...ight-help.html
Transmission Nuetral Saftey switch
https://dodgeforum.com/forum/1st-gen...ml#post2642407
Replacement of Trans 3-4 Shift Solenoid
Solenoid Replacement and Location:
How To Install Overdrive/lockup, Gov. Pressure And Tranducer Solenoids
https://dodgeforum.com/forum/1st-gen...ml#post2944329
Transmission pump/TC leak
https://dodgeforum.com/forum/1st-gen...-help-plz.html
Transfer Case
Axle bind causing T-case to stay engaged:
https://dodgeforum.com/forum/1st-gen...ow-hi-awd.html
https://dodgeforum.com/forum/1st-gen...nv-242-hd.html
Transfer Case Control Module (TCCM) 2001-2003 only!
https://dodgeforum.com/forum/1st-gen...tion-tccm.html
NV242HD Blown UP!
https://dodgeforum.com/forum/1st-gen...-exploded.html
Proper Linkage Connection
LSD(Limited Slip differential)
https://dodgeforum.com/forum/1st-gen...planation.html
Rust
https://dodgeforum.com/forum/1st-gen...rust-spot.html
Tune Up
5.2L and 5.9L including Performance (Cap/Rotor and Plugs)
https://dodgeforum.com/forum/1st-gen...-ignition.html
https://dodgeforum.com/forum/1st-gen...hange-out.html
https://dodgeforum.com/forum/1st-gen...-plugs-ok.html
(How to read spark plugs)
https://dodgeforum.com/forum/1st-gen...ml#post2030778
Plugs 101
https://dodgeforum.com/forum/1st-gen...lp-please.html
Differential
Rebuild For Trac-Lok Limited Slip Differential
https://dodgeforum.com/forum/1st-gen...c-lok-lsd.html
https://dodgeforum.com/forum/1st-gen...n-my-diff.html
http://www2.dana.com/pdf/X5001-CVSP.pdf
Rear Axle Seal Replacement
https://dodgeforum.com/forum/1st-gen...ml#post2372085
46RE Transmission
(Rebuild)
https://dodgeforum.com/forum/1st-gen...d-for-now.html
(46RE Transmission Adjustments)
https://dodgeforum.com/forum/1st-gen...to-tranny.html
Transmission testing (42,44,46RE)
https://dodgeforum.com/forum/1st-gen...-problems.html
Governor Solenoid Rebuild
https://dodgeforum.com/forum/2nd-gen...enoid-diy.html
45RFE/545FRE Transmissions
http://www.hotrodlane.cc/New%20HEMI%...mi%20trans.pdf
45rfe to 545rfe transmission using 2002 Jeep GC TCM
https://dodgeforum.com/forum/1st-gen...ml#post2576846
Transgo Shift Kit Install instructions (45RFE)
http://www.apsprecision.com/45RFE%20...structions.pdf
Tips and Tricks PDF
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
Thermostat and Cylinder head talk
https://dodgeforum.com/forum/1st-gen...d-dealers.html
Auxiliary Electric Fan Motor
https://dodgeforum.com/forum/1st-gen...ml#post2185445
Sliding Drivers Seat Fix
Cigarette Socket and Power Outlets
https://dodgeforum.com/forum/1st-gen...er-socket.html
AMBIENT TEMPERATURE SENSOR (Overhead digital read out)
https://dodgeforum.com/forum/1st-gen...d-display.html
install overhead in trucks without it
https://dodgeforum.com/forum/2nd-gen...d-console.html
Overhead console install DIY WITH PICS
https://dodgeforum.com/forum/1st-gen...o-edition.html
Cooling System Flush
https://dodgeforum.com/forum/1st-gen...much-heat.html
Heater Core Removal
https://dodgeforum.com/forum/1st-gen...ater-core.html
pdf of dashboard removal for 98-00 Durangos
http://www.mediafire.com/?n2mizttz3zj
Dash Light LED swap (98-00)
(courtesy of EndisNear from the 2nd generation Ram section)
https://dodgeforum.com/forum/2nd-gen...tructions.html
Rear Heater core replacement
https://dodgeforum.com/forum/1st-gen...ml#post2405649
Heater Actuators(2002-2003)
https://dodgeforum.com/forum/1st-gen...w-problem.html
Broken Heater Blend Door(2002-2003)
https://dodgeforum.com/forum/1st-gen...ml#post2924387
Wheel Bearing Rebuild Project (Did not work)
https://dodgeforum.com/forum/1st-gen...l-bearing.html
Towing and Gearing
https://dodgeforum.com/forum/1st-gen...-some-fun.html
http://www.allpar.com/model/durango.html
http://www.allpar.com/model/durango-...fications.html
How to tell your gears:
https://dodgeforum.com/forum/1st-gen...hat-gears.html
Electric Brake Controller:
https://dodgeforum.com/forum/1st-gen...ke-assist.html
Complete loss of oil pressure
https://dodgeforum.com/forum/1st-gen...-pressure.html
Replacement Speakers
https://dodgeforum.com/forum/1st-gen...t-speaker.html
https://dodgeforum.com/forum/1st-gen...ty-stereo.html
https://dodgeforum.com/forum/1st-gen...-speakers.html
Speaker Repair
https://dodgeforum.com/forum/1st-gen...er-issues.html
Brake Fluid and Brakes
(Brake Fluid)
https://dodgeforum.com/forum/1st-gen...ml#post2079573
(ABS Brake Light and Speedo)
(Brake Shoes)
https://dodgeforum.com/forum/1st-gen...ml#post2142816
(abs diagnostics)
https://dodgeforum.com/forum/2195359-post17.html
https://dodgeforum.com/forum/1st-gen...m-engaged.html
(abs codes)
https://dodgeforum.com/forum/2196301-post12.html
Power Steering
(Pump 101)
https://dodgeforum.com/forum/1st-gen...ml#post2079651
intermediate shaft problems
https://dodgeforum.com/forum/1st-gen...ml#post2252316
hose replacement 2000-2003
https://dodgeforum.com/forum/1st-gen...ml#post2563344
Fuel Pump
https://dodgeforum.com/forum/1st-gen...l-filters.html
Fuel Injector Replacement
https://dodgeforum.com/forum/1st-gen...ml#post3026044
Alarm Reset
https://dodgeforum.com/forum/1st-gen...going-off.html
CTM
https://dodgeforum.com/forum/1st-gen...t-problem.html
PCM
P0601 code
https://dodgeforum.com/forum/1st-gen...ml#post2327670
Programming new Key fobs
(98-00 'old' interior)
https://dodgeforum.com/forum/2715516-post6.html
(01-03 'new' interior)
Instrument Cluster Reset and Diagnostics
https://dodgeforum.com/forum/1st-gen...ml#post2136829
Indexing the Distributor
(5.2L & 5.9L)
https://dodgeforum.com/forum/1st-gen...er-please.html
Downloads of Information and Durango Service Manuals
Courtesy of shrpshtr325
http://www.mediafire.com/?sharekey=c...b5ba589d1986ba
https://dodgeforum.com/forum/1st-gen...ilability.html
Downloads of DurangoParts Manuals
http://www.mediafire.com/?jh24tgfi6i694
How to Videos
Owners website
access to recall information and replacement owners manuals and build sheet request from dodge
www.dodge.com/owners
Instant build sheet from VIN online(not official, and may not be 100% accurate, but will give you most information)
http://www.compnine.com/vid.php?vin=1b4hs28n11f505789
Miscellaneous Information
http://www.allpar.com/model/durango-...-interior.html
http://en.wikipedia.org/wiki/Dodge_Durango
V8Cowboy (10-05-2021)
Quick Reply: Do It Yourself (top questions and answers) FAQ's
